Only speakerphone works during calls, can't use normal phone mic
everything is super muffled, in-call and on recordings such as base camera app and snapchat. however, speakerphone works just fine.
좋은 질문 입니까?
좋은 질문 입니까?
Hi @pls_help ,
Use a bright light and a magnifying glass to check that the voice inlet hole at the bottom of the phone is not blocked with lint or dust.
If it appears to be blocked DO NOT use a pin or probe to try and clear it as you might damage the microphone which is directly behind the hole.
Try a vacuum cleaner, using short sharp bursts to see if this clears the obstruction.
If it appears not to be blocked and since you state the it is fine when using the speakerphone then there may be a problem with the microphone itself.
해당 답변은 도움이 되었습니까?
I fixed mine by putting my (Pixel 2) phone in some 99% alcohol and blowing hard in the mic hole afterwards. This probably cleaned out the mic.
This is an old post but I just fixed my LGG6 phone with this issue. It is most likely an app that is causing conflict with the microphone. I went into the Settings > Application manager> tap the three small dots at top right of screen> configure apps> App permissions> Microphone. Disable any app that you do not want to have microphone permissions. You can disable all that are active to see it it works then slowly add the ones you want to have active. It will warn you that it will cause the app to not function but it can be reenabled it you need too. This fixed my phone. Hope it helps.
해당 답변은 도움이 되었습니까?
You just saved my life
Thank you so much this totally worked! Bless your tech savvy soul lol
most sensible idea - and worked perfectly
Where do I find application manager?my settings have network sound display and general
Excellent. thank you.
Tried all not working for me on Samsung s6. I think something wrong with dual mic
해당 답변은 도움이 되었습니까?
You need to get an air in a can and blow out all openings possible in phone to clear it out, it worked like a charm for me on my Samsung Android.
해당 답변은 도움이 되었습니까?
24 시간 전: 31
7일 전: 213
30일 전: 866
전체 시간: 91,420
댓글 5개
Blub 의
i can not make calls without phone being on speaker. Cant hear it ring either pixal 3a
Diane K MacMaster 의
I had this issue before and it turned out I needed to update the phone app. Im having the issue again but the phone app is up to date this time.
Megan Tibbs 의
Hi, just wanted to say I had this exact same problem today - audio in calls would play on the loudspeaker, but not the regular one. Apps wouldn't play any audio at all. I noticed when playing youtube, that my app was suggesting that the audio output was going to my headphones, so I used a pin and removed a small piece of debris from the mic jack - the phone now works as it shouold.
louis_cowan 의
I can do all these steps change the mic but problem not solved in my note 3.
Malik wajdan ali 의
