주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Replacement assembly missing home button ribbon cable
I have an iPhone 6S model A1688, and recently got an LCD/digitizer replacement. I made sure I got the correct one from ifixit, on the box it says iPhone 6S, compatibility A1633 and A1688, and started my repair. Everything was going smooth until I realized that my replacement assembly did not come with a home button ribbon cable attached! Not only that, it seems, as I started to inspect my part more thoroughly, that the attached plastic border may also be wrong or different than what is supposed to be because the metal plate does not line up with all the correct spots to keep it in place. In fact one spot is missing: the spot near the top of the plate, next to where the camera assembly and all those components go. I have pictures that hopefully will show my situation a little better.
Here is my original assembly with the home button ribbon
Notice the replacement is missing the ribbon, and it was not damaged or ripped off
Original, with spot to screw in metal plate
Replacement, with the spot missing
Please help me figure this out, or do I have to go out and get another replacement assembly? This one was was bought this way, and is incorrect.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Absolutely right. Thank you.
댓글 달기
답변 1개
선택된 답변
You were given the incorrect screen.
The screen you received was for an iPhone 6 and not an iPhone 6s. Contact iFixit for an replacement.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Andrew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 308
