주요 콘텐츠로 건너뛰기
Could I put a 2007 logic board in this?
Hey guys,
So my 2006 MacBook Pro has a logic board problem which causes red everywhere that there is black which is super annoying but it goes away when I plug it into a external monitor.
But that’s not the question, so anyway, I was wondering if I could put a 2007 Core 2 Duo logic board into it to replacing the existing Core Duo logic board?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Are you sure you want to put the money into a system which has known GPU issues. You will likely need to swap out other parts as well as Apple altered the display and keyboard subsystems.
This is a money pit I would recommend looking at getting a newer Unibody system (new or used) ideally a i5/i7 model.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for the input I will most likely get an slightly newer windows laptop as all I was using this for was gaming with windows xp but didn’t want to spend to much extra money if I didn’t have to also is there any way to fix the red lines on black???
Sorry no aces up my sleeve here, you need a new GPU chip (new logic board).
댓글 달기
답변을 추가하세요
Noah salinas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 143
