주요 콘텐츠로 건너뛰기
How do I get this smell out?
We just bought a new Tuscon and the new car smell isn't there . At least not like the new car smells Im used to with other cars we've purchased in the past . Air fresheners are touching it and when I turn on the air conditioner its even worse. It smells like the dollar store at the mall just after they get a shipment in from China. Kind of a burnt plastic glue smell. Any help would be greatly appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Did anything work? I just bought a 2020 tuscon and am having this same issue. Its so bad it gives me a headache
댓글 달기
답변 1개
선택된 답변
Mosa its a bamboo charcol air purifier . It works great . The smell your smelling is a true new car smell . its a clash of glues ,epoxies, fresh paint with a touch of reducers and hardeners and if you have a leather interior , new leather. This car was probably made in South Korea and they don't use Nu there . Nu is used on new cars in North America to cover the bad smells associated with a new car. Air fresheners just mask the smell the Mosa air purifier will remove the smell over time
https://www.amazon.com/Moso-Natural-Puri...
I'd use about 3 front back and rear of the car. Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
Is there a smell to this ? The last thing I need is more smells
no its just an air purifier
@sanf actually don't leave the bag in direct sunlight as this is how you clean then and get them to release the odder they absorb . It will stink then . this is actually how you clean them . It tells you to set them outside in the direct sunlight for an hour and then it releases whatever it has absorbed. and the filter is good again
Thanks Ill give this a try and get back to you
I want to add to @jimfixer's great suggestion. Also try changing out your cabin air filter with a fresh activated charcoal one. This will also help absorb odors. https://www.framfreshbreeze.com/
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
andy sandford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 39
전체 시간: 803
