주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
MacBook Pro 17" 2009 doesn't power on even after keyboard replacement
I've just decided to replace my keyboard since some keys don't work anymore. For this, I had to disassemble it. I've spent a long time trying to connect the keyboard flat ribbon and after finished, I'd power it on and it powered on normally. I turn it off in order to replace the back cover. When I've tried to turn it on, it didn't work anymore. No lights, no fans but the battery was still charging. I've decided to use the power pads to power it on and it works. I've then imagined being the new keyboard and I reconnected the old one. Surprisingly, it still didn't work. What could have been happened? Could somebody help me?
Cheers
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
@gersoncruz did you ever get this fixed?
Not yet, but I discovered that the problem is on the mainboard. It works properly when the battery is connected but when I tried to use it only powered by the magsafe, it doesn't works. I don't know what could be happen, maybe some SMC issue.
댓글 달기
답변 3개
선택된 답변
I don’t agree with statement that 17’’ MacBook Pro won’t boot without battery. I have two 17” and one of them is old Santa Rosa model and I’m using it in my summer house without battery for almost 2 years without any problem, so the booting problem lies somewhere else. My guess is not tight connection with mother board and when you place the battery the connection with motherboard is established. Check the flat connection cable, maybe is damage and replace it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
If you are saying the problem is that it won’t boot without the battery, this is very common with the 17” machines. It seems the 17” needs more power to boot than the mag-safe will supply. Now if the machine is warm, it will sometimes boot.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
If it works with the battery connected, as you say, but not without the battery connected, then leave the battery connected. I have seen the same issue. But since we want the battery connected anyways, just run it as such.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gerson Bernardo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 203
