Can't play any of the tunes on my iPod Classic
Hi
Yesterday I attempted to delete about 20 songs from my IPOD Classic 80gb using Music Bee. I usually highlight the titles I wish to delete, then right click on them and click delete without any problems. However, on this occasion, the screen locked up and when it came back up, my IPOD was not showing any music (it had nearly 6000 songs on it). Further investigation has revealed they have gone into a new folder extension called 'storage', which when opened, has all the usual folders within it (calendars, contacts, Ipod control, Music, Notes & recordings). If I click on storage and then music, all my files appear and I can play them from that on my PC (through Music Bee) but I cannot play them on my IPOD away from the computer. Before anyone suggests using ITunes, my computer cannot accept ITunes for some reason (I have tried numerous attempts to get it to install), which is the reason I ended up with Music Bee which I enjoy using. I don't want to wipe it clean and start again as apart from the CD derived tracks, I have a lot of ones from other sources so this would take me many, many hours. Hopefully someone can help me. Thanks in advance. Peter
좋은 질문 입니까?
댓글 11개
Further to my original post from yesterday, I have tried adding some tracks directly from CDs and whilst all appeared to go correctly while connected to my PC (and indeed they appeared in the correct 'music' folder), when I disconnected the Ipod, the songs are not there.
georgeformbyjnrfan 의
Although it's several years ago that I got the Ipod, if I remember correctly, I may have used the then current version of ITunes for a while until it no longer worked for some reason. Then I switched to Music Bee which I have used ever since.
Today I have run the diagnostics mode on my Ipod Classic. The results were as follows and hopefully this means more to some of you than it does to me.
Retracts: 42
Reallocs: 0
Pending Sectors: 0
Power On Hours: 5195
Start/Stops: 36,352
Temp Current: 25c
Temp Min: 2c
Temp Max: 53c
There are no pending sectors or reallocated sectors. This means the hard drive is healthy. The rest are usage statistics and operating temperatures.
S W 의
Thank you. What do you think I should do next?
댓글 6개 더보기
