주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
After screen replacement home button hits 3/4 times
When I press the button, my iPhone vibrates 3/4 times.
This happened when I replaced my iPhone 7 screen with an original screen.
Can you help me with this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
This is most likely due to either the screw on the back of the home button being too tight/loose. If this is not the cause then it is probably a short in the home button.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I will try to make the screw lose. I let you know!
Not working :(
If that didn't fix it then the home button was damaged or isnt connected right. This can also be caused by using a Chinese replica screen that is not good quality.
댓글 달기
Reinstall the home button or try anther home button to have a try.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If you use another home button, it wont work at all. Try using the original home button. If not then there isn't much you can do
댓글 달기
답변을 추가하세요
Nerd 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 124
