주요 콘텐츠로 건너뛰기
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 질문 전체 보기
Installed a replacement screen - Vertical flickering issue
See this video: https://streamable.com/ktkw1
This only happens when the screen is turned on, either when the phone is booted up or awaken from sleep. This issue happens for a few mins then it goes away. The screen looks fine afterwards.
Touchscreen functionality is OK.
I would like to know if this is a defect in the replacement screen or something I messed up during installation i.e. connection etc?
Can someone also explain what is causing this issue? And why does it go away after a few minutes?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It's hard to pinpoint the exact reason for this issue, but the problem may arise because of poor connectivity to the phone's "motherboard" or chip, from pressure on a portion of the LCD that was created during reassembly, or simply environmental factors like heat or cold air. I would recommend reassembling the device. If the condition continues it may be safe to look for a replacement LCD.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Muhammad Sarwar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 223
