주요 콘텐츠로 건너뛰기
The Solar-Breeze NX is a robotic pool cleaner funded by Kickstarter and produced by Solar-Breeze.
2 질문 전체 보기
The left front wheel of my solar breeze keeps making a clicking sound
one of the wheels on my solar breeze keeps making a clicking sound when the wheel tries to engage.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
In my case, the cone-shaped horizontal pinion gear is worn and not engaging with the opposing gear. I have a replacement part but don’t know how to remove the pin that the cone gear attaches to. Any ideas?
댓글 달기
답변 3개
I started having the same problem today. Did you end up finding a solution to it?
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
the unit will not charge
the unit will not take a charge
댓글 달기
I have the same problem too. On reading the user manual I noticed that they say to never rest the panel on the front wheels. I might have done that a few times to charge it and thus might have bent it. I did infact try to repair it by removing the covers, I saw nothing there blocking the wheel. The wheels do work if you put a small pressure on them but they stop working after a few seconds. I will try to dig into it again sometime.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My front wheels also started to make noise. You can contact the company and they'll sell you a "front gear platform" replacement kit which you can install yourself as per their published video https://youtu.be/kGRnaAwNPjU
Or you can purchase RX for your NX maintenance plan where you send the unit to them and they replace whatever needs to be replaced as per https://solar-breeze.com/product/rx-nx-s...
For me, rather than replacing many components in SolarBreeze every year or two.... I'm considering a more wholistic solar solution from http://www.naturalcurrent.com/sunray-sol...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John Skunca 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 22
전체 시간: 2,796
