주요 콘텐츠로 건너뛰기
Shark Navigator Lift-Away (NV352) is a type of vacuum that functions on both hardwood and carpet with a lift-away feature. The NV352 includes several cleaning attachments. The vacuum was released in 2008 and is often referred to as the Shark Navigator Lift-Away.
10 질문 전체 보기
How do I switch the setting from “carpet” to “bare floor”?
I would really like to use this vacuum on my hardwood floors, but I am not sure how I can adjust it from its carpet setting.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
The power button actually has 3 settings: II, I, and 0. The 0 setting is for off, while the II and I settings both turn the vacuum on. The II setting is for carpet and the I setting is for bare floors, so adjust the power switch accordingly. The power button is located just behind the dust canister.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Do you close the red power suction on
the side of the hose when vacuuming carpets
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The power switch has 3 positions. The first one is off. It has a O on the switch. This turns off the vacuum cleaner. The second position is on. Suction only for hard floors. Looks like this I. Last position is suction AND roller brush on for carpeted floors. Looks like this ll.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vincent Leuzze 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 28
30일 전: 85
전체 시간: 10,216
