Why won't my device turn on?
Even when I charge my device, it won't turn on. What could be the issue?
좋은 질문 입니까?
좋은 질문 입니까?
The device's battery may be worn out and unable to recharge. To replace the battery, you will need to remove the bottom panel of your 2DS XL Device. After the panel is removed, you will have access to the battery and can replace it. For further help with replacing the battery, refer to our battery replacement guide.
해당 답변은 도움이 되었습니까?
try to charge the nintendo. Its probably out of battery.
try to go to the service centre. They will tell you what's the problem
try to change the battery.
or, try to service the screen. It may be broken.
해당 답변은 도움이 되었습니까?
if the screen(s) were broken the blue light would still turn on, and you would hear sound
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 4,819
댓글 1개
Mines does that to I charge to fill battery and it does not come on
Aliyah Prewitt 의
