주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
Battery tempature too low.
Hello today i bought a new motherboard for my Galaxy s5. When i replaced it and I tried to charge it I got the Battery temperature too low warning. I tried a new usb board it didn't work I tried a different battery it didn't work again I tried my old motherboard and it was working fine , so it seems that the motherboard that i bought is faulty is there a way to fix it with soldiering ? or any other solutions. Thanks Have a nice day.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I would say maybe switch out the charging port, but if it works with your old motherboard, I'd say that's not the issue.
Will it charge when it's switched off? If so, that might be a temporary work-around.
On the topic, this video shows a missing resistor on the charging port after a fall. 39K, for reference. Again, I don't think that's the issue you're having, but maybe compare the two and look for any missing parts or faulty connections.
What was wrong with the old mother board?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Wizzle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 382
