주요 콘텐츠로 건너뛰기
2009-2012년 사이 제작된 13” 화면 Unibody MacBook Pro 모델.
4630 질문 전체 보기
Front Glass replacement tools question
I read the guide for replacing the front glass on a 2011 MacBook Pro 13"and have a question (or two)
Rather than using a heat gun, would the iOpener provide enough heat to soften the glue?
Would the iSclack provide enough force to lift the glass up far enough to get a spudger in the opening.?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I would say it's worth a try with the iOpener, but do be aware of that soft rubber strip mentioned in Step 15 of the guide. I would think the problem would be constantly stopping and reheating, which would give the glue time to cool down again. Then again, it works for a tablet, and that's a big enough area.
MacBook Pro 13" Unibody Mid 2009 Front Display Glass Replacement
As far as the iSlack goes, I don't know if it would provide enough force. My other concern is that it tends to pop suddenly if it gets too much give. For an iPhone, that's fine. The whole display is small and detaches at the same time. If it is indeed enough force to pull the front glass of a laptop apart, I'd be nervous about the glass shattering. More than that, I'd be nervous about any broken glass damaging the LCD. Otherwise I would also say, worth a try.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Steve 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 51
