주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volkswagen Passat B6 및 B7 버전은 독일 자동차 제조사인 Volkswagen에서 생산한 전륜 엔진 대형 패밀리카입니다. Passat B6 라인은 2005년에서 2010년 사이에 생산되었으며, B7 라인은 B6 라인의 페이스리프트 모델로 2010년에서 2015년 사이에 생산되었습니다.
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
this worked for me omg thank you so much
Glad it worked, pass it along...
댓글 달기
답변 3개
가장 유용한 답변
Push on brake and hit button forgear shifter a couple of times.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
It worked for me. Thank you!!
댓글 달기
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I was programming my remote key fob now the fob is stuck in the ignition
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
댓글 달기
Is there a battery in the fob?
If the five won’t come out of the ignition?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Darby Rosello 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 40
전체 시간: 22,433
