주요 콘텐츠로 건너뛰기
모델 A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
50 질문 전체 보기
Can my iMac 21.5 Mid 2014 replace HDD
I have an iMac 21.5 Mid 2014 EMC 2085
My internal Hard Drive have a lot of bad sector and work really slow. I'm going to replace it I wonder if this iMac can use any 3rd party Hard Drive or it need extra temperature sensor to make everything work as normal. Can anyone confirm this. Original HDD from my apple authorized really expensive.
Thank you very much.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I thought you did need the thermal sensor but the OWC site is not showing it for the 2014:
https://eshop.macsales.com/upgrades/imac...
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
@mayer - The 'Thin Series' 21.5" models use 2.5" drives and use SMART services natively. It's only the 3.5" drived modes that need the OWC in-line sensor.
The only rub here is you need a drive that supports the newest version of SMART this is were things get messy as many aren't publishing what they support so you can get into trouble using to old a drive. The OWC drives offered in your link are good!
@mayer @danj I will try order OWC Hard Drive without thermal sensor first to see if it work. This is very helpful. Thank you very much.
댓글 달기
귀하의 답변을 추가하세요
STSSP29 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,659
