주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Error -1 iPhone 7 plus
a customer brought in a iphone 7 plus for a screen repair, but it had a broken lcd so i was unable to test it before i opened it. (note ive fixed about 30 7/7plus without issues.) anyway after installing the new screen I found the phone lagging and freezing up. but it wasnt my screen because the power button was also lagging and when i opened voice memos the record icon was unable to be pressed, also i only use oem apple lcd replacement parts, refurbished by myself so i know they arent fake. anyway I tried to restore the phone to see if that would fix it because i know there have been alot of issues with ios11 and im getting error -1 and now the phone is stuck in recovery mode...if tried updating/and restoring in dfu still not working. another note i tried both itunes and 3utools. when i flash on 3u i can see that it fails at 80% when trying to flash fuddata.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 3개
Will jailbreaking at least get it running? I don't care if I can't make phone calls
Replacement U3601 will solve the problem
Евгений Сухарев excellent bro .
i am at turkey . everytime you can take free beer by me
댓글 달기
답변 4개
가장 유용한 답변
Change IC u3601 and flash firmware again
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I hope I’ve seen your comment earlier, so it would save me hours of checking and fix.
댓글 달기
This is a pretty old error code. Try this
https://m.youtube.com/watch?v=8OYjEP8xtB...
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Lol its an iPhone 7 plus on iOS 11.. I highly doubt that program is even compatible.
Any luck on this !?also got the exact same problem and I'm there's no one here that can do micro soldering
@theimedic -- HEY How's it going, long time no see. You Ok?
It was audio ic
How to fix this? Thanks
댓글 달기
This is the classic error code for baseband issue now recalled by Apple on iphone 7 Model A1660 only. You need to take it to a real Apple store and they will send to Apple to determine replacement eligibility.
https://www.apple.com/support/iphone-7-n...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
iPhone error 1? Joyoshare Ultfix can help you repair it without data loss. I used it to do the same.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
lukerockhill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 21
전체 시간: 7,363
