주요 콘텐츠로 건너뛰기
2016년 6월에 출시된 Samsung의 피트니스-중심 스마트워치
50 질문 전체 보기
Gear Fit 2 no turning on...again
My gear fit 2 will not turn on. It does not show as charging either. I put it on the charger last night with 20% charge remaining and this morning it will not turn on or show as charging. I had the same problem a month ago and it was sent to Samsung repair centre in Toronto. It was returned working and fixed under warranty. Now I am in Florida and it does not work less than a week later. What should I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Hold Down the power button while placing it on the charger. Hold for 30 seconds and let go. charging light should stay on..
-Warner
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I tried it, then the screen appeared all white. I hit the button again and the lightning bolt comes out at 1% then it goes back to a full white screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
In my watch charging symbol is showing and turning off
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Don Newton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 2,005
