주요 콘텐츠로 건너뛰기
A jack-in-the-box is a children's toy that outwardly consists of a box with a crank. When the crank is turned, it plays a melody, often "Pop Goes the Weasel". At the end of the tune there is a "surprise", the lid pops open and a figure, usually a clown or jester, pops out of the box.
How do I open it to fix the mechanism?
My little girl's toy jack in the box (exactly the same as pictured above) has stopped playing music and popping up. You can hear something rattling inside so I guess a part of the mechanism has broken, is there a way to get inside to take look and then fix it again?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
my jack in box will not pop up any longer, how do I fix it?
My son's sock monkey is broken too.
댓글 달기
답변 6개
가장 유용한 답변
My granddaughter's toy is identical, and had the same rattling sound and the same free-turning crank that didn't do anything.
I watched the old Mattel youtube that showed the top being sealed the way the rim on a can is sealed. The innards are different now - they match the "what's inside" youtube rather than the Mattel one.
I cut open the bottom on 3 sides. The metal is thin so I used a box knife. As I was cutting it reminded me of opening a can of beans by the campfire, so I thought a can opener would also work but I was already done.
The loose piece inside was a metal pin about 1 centimeter long. It goes in the end of the music-box drum. Without the pin the gears on the end of the drum don't engage the worm on the crankshaft.
The jack is a sock mounted over a cardboard cone with a spring inside. This assembly comes out with a simple pull. When it goes back it fits over a circular rim under the lid. Line jack up with the lid so he's facing the way you want.
With needle-nose pliers and lots of patience I got the pin back into the drum. At first it went partway and the crank didn't work very well. I pushed it in further and the toy started working normally.
I used Gorilla tape to hold the bottom back in place. It's crude but effective, and it is the bottom.
Our granddaughter is all smiles now, and I only lost a little blood to the sharp edges, a pretty good trade. That wayward pin is only held in by pressure and good intentions, so it may work its way out again after some more drops on the floor.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
I need to fit the earn on my jack in the box toy
댓글 달기
This video might give you some idea of the inner workings, at least in principle. They get into it using a Dremel, which I assume is not how you plan to get into your Jack-In-The-Box.
This old video shows how they used to be put together, which might still be relevant and provide a clue as to how to open it.
However you do end up getting inside, might I suggest documenting it and posting it as a guide on the device page? https://www.ifixit.com/Guide/new/Device/...
Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
The dremel video was very helpful to see the innards, but they were just showing off the insides, with no intention of putting the toy back together. I opened mine from the bottom instead.
how did you open it
댓글 달기
I'm 7 years Old and I wanted to fix my Jack in the box because of the music and then I just broke the music and I don't know how to put it back together again
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Mine is not metal its all plastic, which chipped when I tried to cut into it.
댓글 달기
Next time I will try the crimping type of Can Opener. This time I used needle nose plyers to uncrimp all the way around then when I had to reconnect the base, I recrimped it the same way, it was very sharp so I used vinyl over the base afterwards. Good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The rim looks like it’s sealed up, just like a tin can. I cut open the bottom on 3 sides using a box knife. Others have used a Dremel tool. A can opener might also work.
I won’t be as pretty on the bottom when you seal it back up with tape, hot glue, or whatever.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Same with me,,,and awaaaaay we go!
Ok how do I fix mines can u plz help I'm going crazy
댓글 달기
Just had the exact problem with my daughters! The pin had fallen out. Such a shame I had to cut it open to fix it! But works perfect again.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
You're a master. You'r hired ! What's your address?
댓글 달기
답변을 추가하세요
Kim Richards 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 34
지난 30일: 185
전체 시간: 18,372
