주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
369 질문 전체 보기
Samsung Logo appears and goes Black Screen and LED stays solid blue
This unit has been getting to me.
The initial issue was a random OS installed was causing some issues with Samsung features. He also noted that the phone would restart itself time by time for no reason.
Thinking it was no biggie, I flashed the OS with the stock OS from Samsung Switch.
I was able to back it up, restore the information, all good!
Turned it off and left it charging so his notification would not constantly ring.
Came back to turn it on. The Samsung S7 Logo appears and then black screen and solid LED Blue.
None of the manual commands work - - Power + Vol Down + Up, etc. I eventually left it alone to die and came back plugged it into the charger, works. Try to turn it on, same issue.
Is this the board causing the issue or a possible corrupted OS?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Board needed to be replace, unsure what exactly happened to it. Replacement did the work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Does replacing the board result in the loss of all the phone data?
Yes, as the memory is on a memory chip the logic board on every phone.
댓글 달기
귀하의 답변을 추가하세요
Juax 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 11
전체 시간: 787
