Why can't I get it past the email part?
I reset this tablet once and sense then it will not get past the part where u put your email in
좋은 질문입니까?
좋은 질문입니까?
@britbiersack it requires this email to be the one that was used to originally sign in. If you do not have that, or if you are not the original owner, you are going to run into some trouble with that. Check on here for a possible solution. Otherwise check youtube.com for more options.
이 답변이 도움이 되었나요?
Check out the best technique to bypass the factory reset process using this FRP Bypass APK
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 168
