주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Stuck in deeper dfu-mode
Hy everyone!
Got an Iphone 6 plus from a friend witch fell down on the floor and broke the screen and battery.
Got me a replacement for the battery and now i am stuck in the dfu-mode.
If i connect the phone to the pc, itunes say's that it found the device and need's to restore it. And then it tell's me that there is no software for this device available.
The update button is greyed out.
Itunes is up to date!
I think it could be a hardware related problem but i don't know where to start.
I could try to heat up some parts of the logicboard.
But what...?
Thanks for any hint!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 5개:
download reiboot and see if it will take it out of dfu
you could also try 3utools.com, download it, take it out of DFU and try to update it there. What is the current IOS on it? Are you using Vista or windows 7 or 10?
Allready tried Reiboot, it doesn't recognise the phone as connected...
Thanks
I am using win 10 64, and i don't know that was on there. My guess is ios9.
The main problem is i can't get out of dfu mode. And i don't see any apple logo because of broken screen. 3utools tells me i have to press that buttons i allready did.
if in DFU mode, even having a working screen would not show an apple logo as DFU will not show anything but a black screen. What message is 3Utools giving you exactly?
댓글 달기
답변 3개
there is nothing i can do... just a hint
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
First, I would try to reset/flash it and see if successful. It should kick you out of DFU mode during the flash...but either way will need to get a working screen to continue with setup if successful so you can see the progress.
waiting for idevice and something like device not supported/ unsuported hardware
Hmmm....I have not ran into that before so I guess I hit a roadblock with you, but hopefully someone will pick it up from here that knows what is going on. Just curious, have you disconnected battery, then remove the screen. disconnect back camera too and all flex cables except the charging port. Reconnect battery and then connect back to 3Utools or Itunes and try from there?
yes, i tried. Thanks for now!
Let me know what you find...I am curious to know...Best of luck!
댓글 달기
i don't get it!
해당 답변은 도움이 되었습니까?
점수 0
댓글 7개:
I honestly don't know either...unless you have a corrupted NAND and it needs reprogrammed with Naviplus. I will wait to see what others think as I have not experienced this before and don't want to misguide you
Thanks for no anyway, I'll let you know if i find anything in this case"
have you turned off find my phone in icloud
The phone is definitely not in condition to communicate with any server..
at least that one thing i know
You can still log into icloud.com from computer and delete the device from your device list to turn off find my iphone. Im not sure if it will make a difference or is somehow stopping you from restoring due to the security, but worth a shot
댓글 2개 더보기
댓글 달기
u can change q1403
thank me later
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This question was 3 years ago.
댓글 달기
귀하의 답변을 추가하세요
mischakuh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 2,321
