주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
iPhone 7 which is dead
i have an iphone 7 which is dead i tried everything i could but nothing, i measured every single caps on the board but no short and ,also i did connect it to a power supply zero amps , but when tries to boot up it goes up to 0.06 or 0.07 ma and stays there
i was wondering if someone can help ,also i measured voltages from PMIC
all the rails have the right voltages :{
and i tried to make it hot with power supply but as the currents consuming is very low it doesn't produce enough heat
thanks for reading :)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 9개:
did you check tristar
Or batt_main?
Yes i did replaced the tristar and batt_main is work well as i get normall voltages from pmic
is it taking amps on the power supply without the power button being pressed
hi ,no it does't
댓글 4개 더보기
댓글 달기
답변 1개
I also got a problem like that but i solved with by changing U2 ic.Most of the iPhone dead with by using copy charger,
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
i already tried that
댓글 달기
답변을 추가하세요
yousef 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 315
