주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Taptic engine not working - how to test outside of phone.
I got a client's phone today that is not vibrating. It was previously jailbroken, and had the issue a few months after that. Now after damage, no signs of drops, I'm the "first one" in it. (found some finger prints in the speaker)
I'm not sure if it has a bad lightning assembly, taptic engine or something else. I don't have spare parts to test at the moment. Any idea how to test it outside of circuit? Or any pin outs for it? Ideally I'll have another iPhone 6sp come in to try this one in that phone, but I'm not holding my breath.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
could you not add voltage to it guessing about 3v
I could, but with what current and to what pins? It has a flex cable going to the lightning dock with about 10 pins I think? I don't have it in front of me.
댓글 달기
답변 3개
가장 유용한 답변
Try to get a dc power supply and take out the Taptic Engine then slowly increase the voltage to it to see if it moves. Or get a multimeter and measure the voltage across the pins on the lightning connector and make it vibrate and see if any voltage comes up.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
ideally you should get some test parts as trying to test it could be the hard part and still not lead anywhere
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Yep, ideally I would. But I am looking for another solution that's why I posted here and why I said I don't have any test parts. Unfortunately I don't see any output on ZXW for its plug as it is on the lightning assembly.
Do you have a working one? An oscilloscope you could test the output frequency and voltage with? That would be super helpful.
i dont only iphone 6 and i dont use an oscilloscope, can you not change vibration settings in sound to see if it works
댓글 달기
I have this problem with my 5S, he must of installed some Taptic tweak. If you press the bower button and volume up and down buttons at the same time you should feel a vibrate. Sadly updating the phone doesn’t fix it, and neither is restoring the phone from a back up.
The Fix. You will have to reset the entire phone and not restore it from a back up.
(Back up info just in case)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I did a DFU restore from a new firmware I downloaded from Apple. 11.0.3. Phone is like new now, but still no luck on the Taptic problem... I think tomorrow I will recieve the parts, but the person needed their phone back - Maybe I will get my hands on it again in the future.
댓글 달기
귀하의 답변을 추가하세요
Joseph Hughes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 22
전체 시간: 4,670
