주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Mobile Communications에서 개발한 Android 스마트폰입니다. 2016년 7월에 출시되었으며 모델 번호는 F3213입니다.
Problems in screen and charging
My screen has Black area at prephrary and the brightness is pale, the screen also has black lines at center , another problem, sometime the phope cant charge
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi, did you drop your phone before? Cause there maybe something inside the phone broken.
1. brightness is pale - The screen flex ribbon maybe damaged, or the display was squeezed by something accidentally which break the internal parts in the LCD. In that case you should replace a new screen and here is
2. black lines at center - Check the screen flex cable, see whether it's loosen or not, cause the flex cable maybe loosen which enable only one part of the display shows image.
3. sometime can't charge - check the charge flex cable as well, or reconnect it. It seems the charging port of your phone was damaged.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Ansam Rababah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 20
전체 시간: 1,276
