주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2376 질문 전체 보기
My iPhone is disabled but wont connect to the internet
my iphone 4 is locked out for about 45 years, i have tried to wipe it through itunes but it either asks for a password which i do not remember or it wants it to be connected to the internet which is not possible
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
@ambssharriss how did you do this "have tried to wipe it through itunes"?
댓글 달기
답변 3개
선택된 답변
If you are lucky you may have cellular data enabled and date and time set to change automatically.
In result you should be able to use an activated working sim card with or without mobile data to syncrhonize the date and time and fix the locked for 45 years issue.
This usually occurs when the battery has been flat for a long time or was unplugged resetting the time on the phone to 1/1/1980 which is the system default time.
Otherwise if you can't get the date and time synced then unfortunately you will need to restore the phone through iTunes.
To restore the phone via iTunes you simply switch the phone off, hold the home button and plug the iPhone usb cable to the computer to the phone.
Keep holding the home button until you get the iTunes logo.
Then open up iTunes and click restore.
Depending on how long it takes to download the firmware to restore the phone the phone may kick itself out of recovery mode and then you will need to put the phone back in recovery mode again using the above steps before the download finishes to ensure the restore is perform successfully when the download finishes.
You will most likely need to enter your Apple ID and password linked to the phone during the setup activation stage after completing the restore of your iPhone.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I dont Have a sim i cant take it out of another phone the phone is important to me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
@benjamen50
@benjamen50
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
amber harris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 18
전체 시간: 4,786
