Why can't my Dell Inspiron 1525 charge the replacement battery?
Battery doesn't hold any charge.
좋은 질문 입니까?
좋은 질문 입니까?
Ok so what I would do is look for a replacement battery on Amazon, like this one:
Dell Inspiron 1525 Battery - Amazon
Try using that, and it should work just fine.
- Jasen
해당 답변은 도움이 되었습니까?
if Ur useing a new battery then u probably need to replace the charger port
해당 답변은 도움이 되었습니까?
I have replace the battery & also replace the charger port , then same problem could not charging the battery…..
now what can I do…..?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 409
댓글 3개
Is it a new battery that you're trying to use?
Jasen Friedle 의
No, it's an old replacement battery and the electrical cord is used as well. Has been worked on prior times, not me. Trying to save the laptop since it's my only backup and my Mac doesn't have microsoft cause I can't afford to buy the approved programs.
Maria 의
Use this : Dell AC Adapter LA90PM130
Steve Redtone 의
