주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
iPhone 6 plus flash and then gray?
Hi All,
I'm working for cell phone repair store. Recently, I have experienced 2 iPhones but have no idea what are wrong with them. One is iPhone 6s and one is iPhone 6 plus. If I luckily get the phones on normaly, then suddenly go blank grey(almost black) and no pictures or anything show... If I lift up screen, I saw the backlight is on but on screen show nothing, but grey(it's hard to see grey and at first I thought it was black). If I wait for a white, press home button or power button then the phone show normal then flash several times then go grey again. I have tried to put new screen but there is no help, things still the same. On iPhone 6s more wierd, sometimes I'm able to power it on to home screen(I said sometimes because most the time I powered it on and it go direct to blanks grey screen) but if I moved it around or little touch on screen, it will go blank grey again. Do you guy have any idea.
Thank you very much!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Have you checked to see if the connectors are damaged (the pins).. if they were seated unproperly they could have damaged a single pin and cause it to go out of wack. If the pin is missing on the LCD then try a new screen. If its on the logic board itself, someone who can solder is the only option.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kardon3000kardon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 69
