주요 콘텐츠로 건너뛰기
An industrial gas-powered stove by Vulcan.
The commercial stove oven does not stay hot
The Vulcan Gas Stove at work does not stay hot. We are not sure what is causing the stove to not retain heat.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
No answer? How about a more descriptive question?
Comes on for 12 minutes goes out pilot light and all
Manon First see it is using an igniter or a pilot light.
댓글 달기
답변 1개
가장 유용한 답변
Sounds like a gas pressure issue, make sure the gas lines are not bound or pinched.
The pilot light should not be off or too low, and should be carefully adjusted to have a low burn to ignite the main burners.
When the main burners are on and suddenly go out, it could be an indication of poor flow of either too much gas or too much air, because air is required for the flames to flaming. A quick through cleaning of the burners should do the trick.
Hope that helps
-SF
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Willymae Smith-McNeal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 243
