주요 콘텐츠로 건너뛰기
The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22 질문 전체 보기
Rog gaming center will not open! Freezes my cp? D:?
'''MY DEVICE WASNT MENTIONED :
ASUS ROG GL753VD-DS71 17.3" Intel Core i7 7th Gen 7700HQ (2.80 GHz) NVIDIA GeForce GTX 1050 16 GB Memory 1 TB HDD Windows 10 Home 64-Bit Gaming Laptop'''
I changed a power setting on the ROG Center, a few weeks prior. After two days, My laptop had an update and had begun to freeze and did not work further-- till I'd have to press the power button for it to be usable. It now does this this every 24 to 36 hours (estimate)?
I close my laptop almost every day and I dont know if that's the reason. But, i started doing some research then realized: It could have been the ROG center. So i thought, okay, simple fix, I'll just revert those changes.
NOPE. The button does nothing but, show that it's processing on my mouse/arrow.
I'd wait a while, nothing.
I'd restart my cp, nothing.
I don't know what to do.
Please help :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
Prepared as well as check in to your itunes account to access your tunes or downloads. https://ituneslogin.us/ iTunes Log In and also responding to much more concerns.
댓글 달기
답변 4개
선택된 답변
Delete the app.
Download the appropriate drivers
Right click and extract the ZIP
Check for subfolders marked setup.exe
Select update or install drivers
Allow unit to reboot
;) Not an expert, I asked on asus chat.
Fixed it babeeee
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Delete the app? so how i can find it?
댓글 달기
have you tried to system restore ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yup.... no go.
댓글 달기
search rog gaming center , open and activate rog key! very easy! good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
So, I dont mean to revive a REALLY old question, but i have been plagued with this issue myself for a long time with my ROG STRIX GL702VSK Laptop. ROG Gaming Center worked fine for around a month, then it all of a sudden stopped working. The ROG Key would not work, nothing. I would get the “ROG Gaming Center is initializing” popout, then nothing. I went digging around in the directory for the program (in my case it was “C:\Program Files (x86)\ASUS\ROG Gaming Center”) and i found an executable file (.exe) by the name of “LaunchROGGamingCenter.exe”. I ran this program as an administrator, and the application OPENED without issues! i made a shortcut on my desktop, and now it is as reliable as the day i got the laptop! Hope that helps somebody!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Paula Pereira 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 15
전체 시간: 23,441
