이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
@michaelbyrd did anything happen to your TV or did this just stat? what have you checkecd? Have you disconnected every input and then just tried one? Checked your menu to see if the input is set right (HDMI, CATV, Composite etc.) Have you tried different inputs? Disconnect your power cord hold the power on button for 60 sec. Then plug your TV in and push and hold the power button. See if that changes anything. If none of that works, you may have to disassemble your TV. Let us know if you are up to it..
oldturkey03 의
