주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Essential G560. 이 노트북은 15.6인치 화면과 숫자 패드가 포함된 풀사이즈 키보드를 갖추고 있습니다.
windows failed to start
hi there
when i switch it on it says window failed to start , a recent hardware or software change might be the cause.how do i fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
This laptop should have a small button which should be right of the power button for the laptop.
Press that key when the laptop is off. It should kick into the Lenovo one-key recovery.
Try doing a system image recovery there to get windows working again. You may need to wipe the hard drive when prompted which you will lose data using that method.
If the recovery does not work or fail then you may have a faulty hard drive that needs to be replaced and then windows reinstalled on it again.
Edit: You should also be able to boot one key recovery by repeatedly pressing F11 after turning the computer on until you see the Boot menu option screen, select enter bios and look for one key recovery through there. Arrow keys on keyboard to navigate bios, enter key to select an item.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Getrude 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 2,895
