주요 콘텐츠로 건너뛰기
Repair and support for the third generation of the Flip portable speaker by JBL.
Why is my JBL making noise?
Does anyone know how to fix problem from this video: https://www.youtube.com/watch?v=5j9E8lN_...
i have the exact same problem, it is very anoying to play it half of the max volume...please help :(
I tried everything, to charge it, update it, with another device, when on full volume it plays normal for about 3 minutes and than it produces that sound and turns off and its not blown drivers because it sounds perfectly on max volume for 3 minutes and then the noise starts....please someone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
Its happening to me also!
You find what to do about it?
Does your battery look too big for its spot? I mean, when I took my speaker to pieces, the plastic part that covers the battery seems to compress it , as if the battery was bigger than it should be. I can't put it back together anymore because of the battery, which is too big. It might be a stupid question but does someone know if a battery can get bigger when you take it into a plane?
my jbl flip 5 keeps turning up by itself plss help!!
Thank you so much.. it’s working 100% now. JBL CHARGE 4 working perfectly on max volume.
댓글 달기
답변 5개
가장 유용한 답변
I had the same problem and I just replaced the battery. No more noises at all!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Run the battery till its completely dead . charge till its 100% then try it
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Thanks for answer, I am going to try this
And did it work?
its working now. thank youuuu
that does not work for me
Thank you so much worked for me. JBL CHARGER 4 working perfectly now without the noice at max volume.
댓글 달기
My speaker makes this weird noise as well when i increase the volume especially when a song has base and its battery dies quick, how can i fix it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same problem, if I play more than half volume my JBL starts cracklin. However, if I plug it in and play full blast, the cracklin is gone. I reckon this has something to do with the battery, but I don't know how to fix it. Maybe replacing the battery?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My JBL speaker sometimes made noises when the speaker was powered on, but with nothing being played. So I remembered a device I bought for my car when I was playing audiobooks thru the speaker system using a plug in the glove box. It is called a ‘Ground Loop Isolator’ (mine is made by Pyle) and when I plugged it into the JBL speaker input, then plugged the device into the computer, the noise disappeared. Got it on Amazon and it now costs $12.79 (October 2020).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sava Andjelic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 43
전체 시간: 16,664
