주요 콘텐츠로 건너뛰기
Repair guides and support for the first generation Grand Cherokee ZJ, an upscale mid-size SUV built by Chrysler's Jeep division.
48 질문 전체 보기
Why I can not get rid of my spongy brake pedal
1996 Jeep Grand Cherokee V8
after Replacing my master cylinder and bleed the brakes according to RR the LR then RF and LF 3 times.
Brake pedal can almost goto floor. After pumping 3 to 4 times better.
Bleed master cylinder brake pipe joints and brass connection block for locking front or rear increase of leaks.
Could NOT crack brake line joints on the anti lock pump units TWO connection.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Did you bench bleed the master cylinder? You must get the air out of there first.
You will then need to bleed the whole system. "Cracking" brake lines will not remove the air. You must force the air out thru bleed screws.
Check online for proper brake bleeding procedure for your vehicle.
A service manual would be a good investment, or download from the internet.
댓글 달기
답변 1개
가장 유용한 답변
There might just not be very much brake pad left, so the pedal almost goes to the floor.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
davehoser Ho 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 6
전체 시간: 368
