주요 콘텐츠로 건너뛰기
Toshiba Portege R830 BIOS Password Reset
Hi All,
i am an exporter of used Desktops/Laptops/Accessories.
Recently i recieved alot containing 73 Pieces of Toshiba Portege R830 i5 2ng Gen, 320 gb hdd, 4 gb Ram and Bios version is 3.90 with EC version 1.6.
but Unfortunately all are BIOS locked and Require Password to BIOS.
can any expert Help me on this.
i have searched forums, they say, rewriting Bios chip or replacing already Programmed BIOS chip wont help me as the Security Passwords are stored on some other I.C.
can any one help me either to Remove this by any method or to identify those JUMPER upon short circutting them i can Bypass the BIOS Password.
thanks in advance.
regards.
wileyson
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Did you fix the problem with the bios password ? I have the same problem.
댓글 달기
답변 2개
가장 유용한 답변
ITT: Shills. Normal as they reply whenever anyone asks this, but the DaosSoft guy stands out as something special at best this is a GUI on Hirens tool, at worse it’s malicious. Regardless, it claims to do nothing but recover credential in windows (W10 is not supported) and the reliance on a boot disk ignores the possibility that the locked bios will only boot from HDD not to mention what the TPM will think.
OK rant over, now I’ll help.
The challenge/response code thing they do may work, but if that is your chosen route try calling Toshiba first and explaining, odds are better they will give you the codes as they are selling the whole laptop division but while rules may be relaxed, good luck finding a number to call or website still live.
Check out the service manual, here is the one for the z930, they are very close models, but this is informational, get one for your exact model(s) before doing anything. Not only are the board schematics there to facilitate your jumper placement, but they reference procedures for rewriting bios and eeprom (likely the IC you were looking for) and other wizardry in detail, pardon me for forgetting, its #500 pages and a great document AND TOTALLY FREE. The Bios rewrite is literally a one click process but Iwill admit the instructions are rather cryptic probably illuminated by reading the reast off the document
https://www.manualslib.com/manual/813546...
Actually, here’s the manual for yours.
https://www.manualslib.com/manual/819245...
Didnt look at the diagrams, but overheard the jumpers you may need are “near the ram”. happy hunting.
Armed with that a DIY Loopback or whatever you may have success, but personally I would use the manual to feign a mobo replacement using the rewriting function of the various modules eeprom bios ec/kvc (fairly sure that is the specific name Toshiba use for the eeprom) but spoofing the DMI with that pulled from a fresh identical system. Read more into the role of the DMI, I’m hazy but Ithink it could help
“NOTE: When replacing the system board, be sure to execute the following procedures.
1. Before replacing the system board, execute subtest03 "DMI information
save" in 3.4 Setting of the hardware configuration in order to save the DMI
information from system board to floppy disk.
2. After replacing the system board, execute the subtest04 "DMI information
recovery" and subtest08 "System configuration display" in 3.4 Setting of the
hardware configuration in order to copy the DMI information and system
information from the floppy disk”
Appologies for length, a link to the manual would have dont just as well. Please update us on this, these bios locks are a peeve of mine and I’d love to get it nailed.
Best of luck
Soni
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Unfortunately, you will likely need to purchase a password unlock service from Ebay.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
hi, ty for reply, on ebay there is no specific password unlock, only Re-Programmed Bios chips, but the seller has mentioned, it wont remove the password. :(
can any one suggest me the JUMPERS on this board, as i tried but could not succeed to identify one.
Yes there is. This service removes that password.
https://www.ebay.com/itm/Unlock-password...
thanks, i think this service is posted after my request here, well the seller has ZERO rating :( and Price is too high, 96$, but again thanks
hi, seller seems does not look into ebay msgs any more :)
There are more thane one sellers. Look for "toshiba bios password unlock" on either the web or ebay.
댓글 달기
답변을 추가하세요
wileyson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 41
전체 시간: 7,135
