주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 2DS는 3D 상단 화면 기능을 제외하고 Nintendo 3DS와 거의 동일한 하드웨어를 갖춘 보급형 휴대용 게임기입니다.
SD card slot problem
When i turned on my 2ds, i got "Could not detect an SD Card. The software on the SD Card could not be displayed." Error message. When i tried the sd card on my computer, it needed to be formatted. The sd card came with the 2ds and is 4gb, but it shows up as raw and only 1gb on my computer. It can no longer be reformatted, i even tried to do a low level format to no avail.
I decided to just get a new microsd card w/ an adaptor (sandisk sdhc 16gb class 10). First time i inserted it and turned the 2ds on, i got the same error. Turned it off and on twice and it worked fine. Next day i turned the 2ds on and got the error again several times. Tried the sd card on my phone and it was fine. It's working fine right now after i took out the sd card and put it back in.
Is the problem with the 2ds card slot? Is it fixable? In its current state, could it mess up the new sd card like it did the old one?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi!
As you suggested, there might be a problem with your SD card reader, and yes, there is a chance that it will mess up your new SD card, tho I wouldn't worry much. While you can't replace the SD card reader on the 2DS without also replacing the motherboard, you could regularly make backups of your data and wear it down until it no longer works at all.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
Chandelure 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 33
전체 시간: 6,264
