주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
New battery doesn't work
I took my phone apart as directed put new battery in and nothing no life...tried charging for several minutes and again nothing. Had to put in the old battery which won't hold charge for very long and phone works.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It seems like you might have received a faulty battery. I would try another one!!
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
How do you recalibrate a battery on an iPhone. Are there software diagnostic tools like Coconut Battery for the Mac? How is the phone being charged and on what?
Coconut Battery works for iOS as well! If phone is not coming on it wont read it unless you have a battery reader, fairly expensive ($300 range). BUT Mayer has a great point. You can plug your phone with your old battery, download coconut battery and make sure you go to the iOS option on the top right. If battery life is below 80% then it needs replacement and this might confirm the bad battery you received as a replacement. ---- Also, make sure to leave that replacement battery plugged in for a little while. Sometimes they drain and take a little bit to come on. -- Let us know, remember to not take broken as an answer!
댓글 달기
귀하의 답변을 추가하세요
Mattie Presson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 65
