주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
327 질문 전체 보기
MacBook Pro fell and is dented. Is it repairable and at what cost?
Hi my MacBook Pro 2017 fell and it was open so mostly landed on the edge of the metal at the top of the screen. It also caught the top left when it’s closed. I still don’t know if there is any internal problems but it seems to be working ok. I noticed the bottom left of the screen has a little glow. This is baaaaad. It’s my work computer and I have to fix it. Any idea how much this could cost? ☹️
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
thanks guys! I have an appointment with the apple store and then I will let you know how it goes. I would consider living with it, but as my work computer, I am responsible for keeping it in the original condition :/
Hey! I know that you posted this a while ago but I was wondering how much it ended up costing to get the repair done? I had something similar happen and was wondering how much it would cost to get it fixed.
댓글 달기
답변 3개
선택된 답변
Being a 2017 model, it's going to be expensive. If you're savvy enough with a screwdriver and have the patience, you can get replacement screens on ebay for probably anywhere around the $300 to $500 range and swap it out yourself. If you bring it to a tech, they will probably charge around $150 to replace it in labor cost.
A new screen from Apple will cost around $900 to probably $1500 depending ... my advice is, if it works, live with it. I've dropped my late model 2013 twice and actually cracked the screen ... twice ... replaced it ... twice ... no bueno!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
At this point Apple is the only source for the part (display assembly). It won't be cheap, but cheaper than buying a new system. I would go the the Apple Store or authorized service center to get an estimate (Apple is free) They can at least tell you what it will cost.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
can anyone tell me will the 300 over all dents
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mika 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 23
전체 시간: 12,637
