주요 콘텐츠로 건너뛰기
Model A1112 / 512 MB or 1 GB capacity
25 질문 전체 보기
How to replace audio jack port iPod first gen - M9724LL/A
My M9724LL/A audio jack is not working properly when inserted to audio jack port. I don't know how to replace it with the new one and which audio jack port to use. Thank you in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello,
The audio jack in one of these is soldered to the motherboard. Which means that you would have to desolder and then solder a new one on. Parts for this can be found on eBay but if you don't know how to solder you would have to replace the whole motherboard which is quite hard. This will also remove everything you have on the device as you wouldn't have the same memory.
Here is a guide on how to remove and replace the motherboard and also a replacement part from ifixit:
iPod Shuffle 1st Generation Battery & Logic Board Replacement
iPod Shuffle Gen 1 Logic Board
Hope that helped
iPod Shuffle Gen 1 Logic Board 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Abhiraj Singh Rathod 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 309
