주요 콘텐츠로 건너뛰기
The Acer Aspire One 532 features over 8 hours of battery life.
5 질문 전체 보기
질문 마감됨
some of my problem pdf files
I created .pdf document on Adobe Acrobat. I’ve no any good idea what can I do after this. This day I’ve opened .pdf, it has demonstrated me white screen. Someone knows, I hope, what can be a solution.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Download the free CutePDF writer.
This will install a PDF "printer".
Print to CutePDf.
See if the CutePDF created version still gives a white screen.
Also, try opening the PDF with Google Chrome.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The cases then nothing can't solve your issue, to open or to repair .pdf document, then take a look at especial instrument unlike to others damaged pdf https://onlinefile.repair/en/pdf.html
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is showing white pdf file because of 2 reasons.
  1. It is corrupted so need to repair the PDF document
  2. It is too heavy in size and thus not supported by your pdf viewer software, you can reduce the size using compress pdf tool.
  3. PDF file is blank from the start so it is showing white background.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi James,
This is a really old topic. Ideally you'd want to reply to newer topics in the list. Always check the date the question was posted before replying to it
Hi Nick,
Thanks for feedback! I am new to this community and don't know the actual process but from next time I will definitely check date before giving my answers.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 66
