주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
Power locks operating poorly with key fob - poor range
I have a 2005 1.8t Jetta GLS wagon with over 133000 miles.
Problem: The key fob range is limited. I must use the key fob from no farther than three to five feet from the driver door in order to unlock, lock or operate the trunk with the key fob.
I have replaced the battery in the key fob.
What else can I do to solve this problem?
The electric trunk hatch opening motor seems to be sluggish as well.
Thanks ifixit community!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
This problem can usually be solved by cleaning the circuit board of the key fob.
The board inside your remote can get a lot more filthy than you think! When the board is dirty it can prohibit the contact to the circuit board when you push down on the button.
Simply wiping the circuit board off can make your key fob like new again!
Here is a video on how to clean your key fob circuit board
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The range of the key fob can some time is controlled by a small SMD Cap around 100nf, if this has deteriorated can affect the distance sometime.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Woody Wiest 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 303
