주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
New Screen not working
I recently bought an iphone 6 plus from ebay with a smashed screen with the hope to replace the screen and use it. The smashed screen works, except from the touch doesnt, so I can see that the phone powers on as usual, battery holds charge etc. When I first replaced the screen, I got no reponse from the device, I thought I had damged something, but when replacing the original screen, it still powered on. I tried again, but still no luck, so I returned that screen assumong it was faulty, I then ordered another replacement screen, with the same problem. Am I just really unlucky and have had two dodgy screens or could there be some damage to a connnector I am missing? I dont think however this could be damage to a connector or otherwise I wouldnt get anything on the broken screen. Please help! Many thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You most likely have Touch Disease on your phone. Google it :) Ask anything if you need help
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi, thanks for the speedy reply! I do know of touch disease, but the weird thing about this is the replacement screens do not show anything, no apple logo no sign of life at all, however I know the phone is working, because it is recognised in itunes, and can be put into recovery mode etc. Any thoughts?
Hold a flashlight to the screen when you turn it on and see if you see a faint image. Also when it powers on all the way, hit the power button quick to wake it and have your flashlight on the screen. It sounds as if there is a bad backlight circuit.
댓글 달기
I'd try a screen from a different supplier as you can get screens with manufacturing defects, I've had this problem before and it was solved with a screen from a different supplier.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
rory highnam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 96
