Display turn Black, after many times turn off and on, sometimes works
My Thunderbolt Display (A1407) stays black after connecting it to my iMac.
After many times unplug the power cable and plug it in again, the picture came back. Unfortunately, it disappears after 30 minutes and does not come anymore. The picture was good, no mistakes.
What could it be? Power cable to the iMac or power supply?
Has anyone else had this problem and how did you fix it?
What would be the most sensible to replace?
Many Thanks
좋은 질문 입니까?
댓글 7개
Try this: Take a flashlight and after turning the display on and plugged into your Mac place the flashlight against the screen at a sharp angle. While faint can you see any of your desktop icons? If you do then we know the issue is within the backlight logic.
Dan 의
Hi Dan, i try it with the flashlight, but i see nothing, its only black. :/
thank you for the note.
mark 의
OK, so we know its more likely a power issue within the display then.
Have you tried another power line cord and made sure the outlet is good? And does the MagSafe cord have power when you use it, the cord LED lit?
Dan 의
Hi Dan,
I have try an other power line cord and it was the same. yes the magsafe is working when i put it in my macbook. and the powerpoint is well, i try other and there was all the same.
mark 의
HI,
I have now tried the new thunderbolt cable, and unfortunately it did not work, the imac recognizes that a thunderbolt display is connected, but it is still black on the display.
sometimes it works, if I leave the Thunderbolt display turned on for a few hours, then turn it off briefly and turn it back on, then comes the picture for maybe 20 minutes.
mark 의
댓글 2개 더보기
