How do I replace the seals in the Thermoblock?
How do I replace the seals in the Jura Avant-garde S8 Thermoblock? The halves need to be separated.
좋은 질문입니까?
좋은 질문입니까?
Look here - but you need to know some german words, or just use Google translate. The right guide is called "Revision des Thermoblocks"
이 답변이 도움이 되었나요?
This is wonderful! On page two of the guide, a tool that looks like a Nut Driver is used for the center bolts. My Thermoblock looks like it uses hex-head bolts and I am not sure I can find a thin Nut Driver to fit in the hex-shaped recessed hole. I will search.
The two bolts should be normal ones of 7 mm. The outer screws should be a Torx ( or Allen, don't remember?)
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 208
