주요 콘텐츠로 건너뛰기
Apple Macintosh 개인용 컴퓨터 수리 안내서 및 분해 정보입니다.
42799 질문 전체 보기
질문 마감됨
Why does my display go off when opened more than 45 degrees?
Why does my display go off when opened more than 45 degrees? Shining light on screen shows images.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
you probably have damaged backlight cable. try to open your screen assembly and have a look on connections.
as you did not provide model number, i cannot look up the right guide. you'll have to do it yourself...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
inverter cable
댓글 달기
Similar problem with my 14" G4 powerbook except that its back light dims badly when the screen is opened more than a couple inches (30 degrees). Seems like a loose connection or something. I don't know how to check the backlight cable or open screen assembly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
john, if you need help with your computer, it is best to ask your own question. Click on the link on the right side of this page "Ask a question" and give as much information as possible. There are lots of Mac Gurus on here that can help you with that. Right now it looks like you are answering a question. Thanks.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 501
