주요 콘텐츠로 건너뛰기
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
20 질문 전체 보기
PSP does not charge from charger.
I have aquired recently a PSP, but it does not charge from it's charger. So, I want to make an USB mod, so i will be able to charge the psp from USB. But I want to charge it from my phone charger or iPad charger, and here is the question, will I burn out my PSP if i will charge it with a charger after USB mod?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
A standard phone charger that outputs 5 volts and anywhere from 0.5 to 2 amps will safetly charge your console.
PS: let me see if I understood what you are trying to do: you want to replace the power-in port of the PSP with some sort of Lightning/ 30-pin solution? You do realize it might be cheaper to get a new charging port/ power adapter/ battery, right?
이 답변이 도움이 되었나요?
점수 3
댓글 7개:
No, the energy controller from my PSP is burnt, and it can not charge from charger. All I want to make is the USB mod so it can charge from upper mini USB port, that is why i ask about charger.
@sanghun But you can charge the console via the upper USB port anyway, you don't need a mod for that
@sanghun It's a standard mini (type B) USB cable, you only need to go to settings
@sanghun On never mind, I just googled the mod you are talking about. Idealy you need something like 1.2 Amps to charge the PSP, but as I said, anything from 0.5 to 2 Amps will be fine, only the charging speed will be different.
I just am afraid to burn the mother board )) but this mod is performed on PSP 1000 because it doesn't support USB charging :D Thanks anyways
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Eugen-Andrew Coliban 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 1,581
