주요 콘텐츠로 건너뛰기
The Toyota RAV4 was redesigned for the 2006 model year using an all-new platform and was first unveiled at the 2005 Frankfurt Motor Show.
11 질문 전체 보기
Where is reset button in order to reset low tire pressure light?
I have checked the pressure in all four tires on my rav 4 2011, Toyota, and the light will not turn off. I do not know where the reset button is and I also have been told the spare tire could possibly be low. Please advise
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 1개
Adding air to the spare tire usually will make the light go off
댓글 달기
답변 4개
가장 유용한 답변
On a modern toyota, the pressure sensors reset automatically.
If the air is filled to the proper levels, drive the car a few miles above 25mph, and the sensors will detect and update the psi on the tires.
Make sure the psi is set to or above the label on the door.
...and yes, one of the few last vehicles on earth with a spare tire -- that needs to be checked as well.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
It's sooo the spare tire. I fell for that for months until a mechanic explained the issue to me.
댓글 달기
I have read on other sites where inflating your tires to 45 psi and then deflating them to the correct level will tell the pressure sensor to re-calibrate.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You’re going to hate this. Did you check the spare tire attached to the back end of the vehicle? That tire has a pressure gage too!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Make sure the psi is set to Showing at the driver door side.Make it same psi ( 32 ) could be.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
maryalicejr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 96
전체 시간: 15,731
