주요 콘텐츠로 건너뛰기
Robot vacuum manufactured by Neato Robotics
4 질문 전체 보기
Why is my neato botvac D75 Keep beeping ask to reset on switch?
my Robotic BOTVAC keeps asking to turn on switch ,But does not make a difference on or off? in it resets it needs to charge battery, after done charging it take off and stops ask to turn on or says need to charge battery?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
I have the same issue. I contacted Neato and worked with their tech department for awhile. Finally the guy said it could be a bad battery and suggested I purchase a new battery. I did that and it is still not working. Just wanted to warn you encase they make that suggestion. I'm going to take mine apart and see if I can see something near the switch.
Als de batterij goed is kontroleer de aan uitschakelaar of deze niet defect is.
De Botvac 85 van ons was de aan uitschakelaar defect.
Te bestellen bij Relchelt bestelnr. ss13lsp
Na vervanging werkte de Botvac85 weer perfect.
댓글 달기
답변 4개
가장 유용한 답변
I have discovered a poor solder job on the switch in my D85.
See before and after pictures below.
Disassembles same as other D models.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Was there a problem before? Did re-solder fix the issue? I have a D80 that has stopped working properly and am looking for some help identifying the issue.
I had a similar issue on my D75. Resoldering seems to help, many thanks for the hint.
But, today I got the "turn my switch to on" message again...
댓글 달기
Mijn Botvac 85 wilde de accu niet opladen en gaaf aan dat deze leeg was.
Accu was in orde nagemeten en was kort ervoor al vervangen omdat de vorige defect was.
In het begin werkte de Botvac 85 nog wel, alleen gaf deze steeds meer problemen.
Aan het laad station werd de accu opgeladen en na korte tijd knipperde het oranje lampje snel.
Ook gaf de Botvac 85 regelmatig aan opvangbak sluiten.
Later viel de botvac 85 uit als deze van de lader werd gehaald.
Oorzaak een defecte voeding schakelaar.
Voor nood even het korte pootje door verbonden met de middelste en de Botvac 85 werk als vanouds.
Het korte pootje is de accu spanning en de middelste is de Botvac 85 zie foto.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I had a very similar problem with my D75. It started asking for switching the power button to ON despite having it in the ON position already and the battery indicator showing empty battery. I opened it and the battery was fully charged even with sustained load (1.5A). It turned out the power switch had bad internal contact (dirty?). The multimeter showed no continuity in ON position. Some IPA alcohol, some ON/OFF exercise and voilá, problem solved (till next time).
댓글 달기
Mine has the same issue. Is this a common problem? Neato should recall the machine.
How can I reach that switch?
Thank you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey there,
We actually had the same problem as well as one where the robot would randomly stop with a "Please clear my path" error (link to my question posting the same information I guess), and then would at other times do this random left-right-left-right freakout, as well as getting the same error you have/had. In our case, it actually turned out to be defective/aging capacitors on the board, and desoldering/replacing these solved the issue! We had already tried a new battery which had fixed the "Please Clear my path" issues in the past, but no dice this time. The capacitors required seem to be relatively standard and available at standard electronics stores, and there are only about 7 of them, but potentially something worth trying for anyone else who has the same issue :)
The exact capacitor type/size I can't remember off the top of my head (think they're Electrolytic 100uf/35v), but if you Google there are some forums (Russian Robotics and Neato forums from memory) that go into this a bit more as to exactly what kind of Caps you need as well.
Hope this helps someone!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Found a couple of the forum links, though not the one I could remember in particular: http://www.robotreviews.com/chat/viewtop...
Still should be a starting point though - different issue, but same capacitors causing it :)
댓글 달기
귀하의 답변을 추가하세요
george bauer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 15
전체 시간: 3,147
