How do I connect my device to the internet?
I want to connect to the internet, but I'm not sure how to do so wirelessly.
좋은 질문입니까?
좋은 질문입니까?
You connect your Amazon Echo Dot through the Alexa app! Go to settings, select your device, and select set up wifi! I am attaching a link which will give more help on connecting your device to the web.
이 답변이 도움이 되었나요?
Connect echo dot device to Wi-Fi network:
Go to Settings option from the left navigational panel.
Select your device and after select update Wi-Fi.
Try to press and hold action button when the light ring changes to an orange and select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network.
이 답변이 도움이 되었나요?
If you want to connect echo dot to a Wi-Fi network, follow the instructions in the Alexa app. Most important thing that is echo dot connects to dual-band Wi-Fi (2.4 GHz/ 5 GHz) networks that use the 802.11a / b / g / n standard. Echo Dot does not connect to ad-hoc (or peer-to-peer) networks.
To learn more, go to '''Connect Echo Dot to Wi-Fi'''
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 6,987
댓글 1개
still unable to connect,used alexa app
Frank Retkowski 의
