주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
MBA Fan not working
Hi, my MBA 13” mid 2012 4GB 1.8 GHz Core i5 stopped working. A friend of mine changed the I/O board and the logic board and it worked for a while, slower upon starting but overall ok when it got going.
I didn’t use for a while and then when I tried to start it, some strange lines appeared on the home screen, fan kicked in at high speed and it went black!
My question is: where is the tempreature sensor on this laptop and how do I know if the fan is working?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I think you have something deeper than a thermal sensor or fan issue.
To answer your question: Your system has a few sensors distributed across the logic board, the battery, and within the CPU its self.
Can you tell us why your friend changed the logic board. Did you have a liquid spill at some point?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Dan,
We changed it because it went black after 3.5 years. I tried the usual resetting SMC, PRAM and then we changed the I/O board, still nothing. Only when we chance the logic board it worked.
(We put in a used one.)
I know this machine is pretty much gone, I’m investigating the reasons for it to stop working twice in such a short time to be due to same reason, that is perhaps the fan or the temperature sensor is faulty.
Thank you for taking interest and trying to help.
댓글 달기
귀하의 답변을 추가하세요
Chief 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 164
