주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Help!, half of my iPhone 6's screen is black.
Half of my screen is black, although all the other features of the iPhone work fine, which is strange. I was outdoors, and I fell on my leg, landing where My phone was, in my pocket. (Screen has not been cracked).
(I have tried powering off my phone off and on, but nothing changed.)
The screen itself works technically , but since the display is black it is extremely difficult to use my iPhone, and I really need help because I I can't buy another iPhone due to the price. Thank you for reading my message.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 3개
I have the same phone as you and the same problem
Same here, how do I fix it?
Same thing here but I also have some red and green specs/ dots
댓글 달기
답변 4개
이 답변은 원래 다른 질문의 답변입니다.
This response is late but hopefully it can help others.
There are two possible causes here. One is a damaged screen assembly. This can be easily replaced by ordering this part and following this guide.
The other possibility is that the backlight circuit was damaged and needs to be repaired. This requires a micro-soldering repair and is not DIY .
iPhone 6 Screen 이미지
상품
iPhone 6 Screen
$44.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
To fix iPhone black screen of death, you can also restore your iPhone through iTunes. However, please make sure you have backed up all your important data from your iPhone via iTunes to restore iPhone with the iTunes backup. And during the process, iTunes will erase all data and settings on your iPhone to fix your iPhone. Now, you can start to fix your iPhone black screen issue.
> Firstly, get a USB cord to link your iPhone to computer and launch iTunes on computer.
> Secondly, click the iPhone icon on iTunes, then hit the Restore iPhone option on the right panel on iTunes window.
> Finally, confirm your action to restore your iPhone on the pop-up window. Then iTunes will start to erase all data and settings on your iPhone, download and install the latest iOS version on your iPhone. Finishing the process, your iPhone black screen issue will be fixed.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
your only option is to replace the whole screen!hope that helps or check the led wires
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You could ask for help from a professional iOS rescue tool - iOS System Recovery to fix your iPhone error. This tool specializes in fixing all types of system problems on iPhone. You can easily operate the program and quickly fix different problems like stuck on Apple logo, iPhone error 9006/53/56, iPhone stuck on recovery mode, iPhone blue/black/white/red screen of death and so on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
K.Coleman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 24,294
